PATS Immobiliser Fault Codes Ford Escort
Nebhotep
Мнение от Nebhotep » 12 мар 2013, 09:28
Introduction
If a fault develops on a vehicle fitted with Ford PATS there are a series of simple checks which can be carried out before proceeding, if necessary, to the FDS2000 diagnostic programme. There are also a number of self-diagnostic two-digit codes which may be displayed by the indicator LED which indicate a specific fault and could avoid the need to proceed with the FDS2000 diagnostic programme.
Note: The indicator LED must be carefully observed and the sequence of flashes noted.
When the two-digit codes are flashed, for example 1:3, a single flash followed by a break, followed by three flashes and a break, will be repeated ten times before the LED finally goes out.
Fault Finding Procedure
Fault - Engine does not start or crank: LED does not illuminate
PATS system fuses in central electric box. Fit or renew as necessary.
If alarm is fitted check whether LED functions for alarm: If OK go to FDS2000. If not OK check cigar lighter fuse (this also supplies power to LED).
Fault - Engine does not start or crank: LED flashes rapidly. (Engine is immobilised but key will not cancel immobilisation)
Check: Leave ignition switched on for at least one minute or until LED starts to flash two-digit code. Note the code being flashed and compare with the following list:-
Code Problem Check
1 : 3 Key code not received is the key obscured, try again with different key, key may be damaged/faulty 1 : 4 Partial code only received is the key obscured, try again with different key, key may be damaged or faulty 1 : 5 Key not programmed to PATS Programme key 1 : 6 Faulty link between PATS and EEC v module check with FDS2000
Programme key
Fault: Engine does not start or crank: LED illuminates for 4 seconds and goes out: (PATS is working correctly, possible fault elsewhere in system)
Check:
Starter solenoid relay, renew if necessary.
If still no start, Go to FDS2000.
Fault: Engine cranks but does not start. LED illuminates for 4 seconds and goes out (PATS is working correctly, fault elsewhere in system)
Check:
Power supply to PCM or fuel pump (diesel), if still no start, Go to FDS2000 Check PCM fault, Go to FDS2000 (Petrol and Gas engines)
Fault: Engine starts but LED stays on.
Check:
Leave ignition on (engine running) for at least one minute or until LED starts to flash two-digit code
2 : 1 Less than three keys programmed into module: vehicle can be driven but one or two more keys should be programmed into memory.
Re: PATS Immobiliser Fault Codes Ford Escort
Мнение от HACKO » 12 мар 2013, 12:28
Не е зле някой да го преведе за малоумници, като мене.
OgiDogi
Местоположение: Сливен
Мнение от OgiDogi » 13 мар 2013, 07:51
Nebhotep написа:PATS Immobiliser Fault Codes
Introduction
Code Problem Check
Programme key
Check:
Check:
Check:
Кодове за грешка на PATS
Въведение
Ако се появи грешка в кола, оборудвана с Ford PATS, има последователност от прости проверки, преди да се пристъпи към диагностичната програма FDS2000. Също така, има и двуцифрени кодове за самодиагностика, които могат да се прочетат от LED индикатора, които показват специфична грешка и могат да предотвратят ползването на диагностичната програма FDS2000.
Забележка: LED индикаторът трябва да се наблюдава внимателно и последователността от мигания да се запише.
Когато индикаторът показва примерно 1:3, единичното светване последвано от пауза, последвано от три светвания и пауза се повтаря десет пъти, преди индикаторът да спре да свети.
Процедура по откриване на грешките.
Грешка - двигателят не завърта и индикаторът не свети
Предпазител на PATS в основната кутия. Сменете с нов, ако е необходимо.
При наличие на аларма, проверете дали индикаторът функционира от алармата. Ако е наред - минавате към FDS2000, ако не - проверете предпазителя за запалката, който осигурява захранване на LED индикатора.
Грешка - двигателят не върти или не пали, индикаторът мига бързо. Двигателят е блокиран, а ключът не може да го отблокира.
Проверка: оставете на контакт поне една минута или докато индикаторът започне да показва двуцифрен код. Запишете кода и сравнете със следният списък:
1:3 не е получен код от ключа, може да не е прочетен правилно или да е повреден. Пробвайте с друг ключ.
1:4 част от кода е получена - същото, като 1:3
1:5 ключът не е програмиран в системата
1:6 лоша връзка между PATS и EEC V модула, проверете с FDS2000
Грешка: двигателят не върти или не стартира, индикаторът светва за 4 секунди и изгасва: системата работи правилно, възможен проблем другаде по системите
Проверка: шалтера на стартера, подмяна при нужда
Ако пак не стартира - минавате към FDS2000.
Грешка: двигателят върти, но не стартира. Индикаторът светва за 4 секунди и изгасва: системата работи правилно, възможен проблем другаде по системите
Проверка: захранване към компютъра или горивната помпа. Ако пак не стартира - FDS2000 и проверка за грешки в компютъра
Грешка: двигателят стартира, но индикаторът продължава да свети
Проверка: оставете на контакт със запален двигател поне една минута или докато индикаторът покаже двуцифрен код
2:1 по-малко от 3 ключа са запаметени в модула, колата може да се кара, но поне още един или два ключа трябва да се програмират.
ДЕ-РУСИФИКАЦИЯ
